Cosi
- Kingscliff
Rockitdoc said:Coils cleaned up nicely.
Put them on the shelf also and replace them with TEKs or Dynos
They're junk
Rockitdoc said:specific recommendations for model numbers, etc?
Cosi said:Put them on the shelf also and replace them with TEKs or Dynos
They're junk
sfcpiet said:Only junk I see in the pic are the plug caps, Cosi...
Coils are just about fuckin' bulletproof! Pity the bracket ain't, it often fractures if not mounted securely.
I use a hook intended for mounting exhaust system springs to extract oil seals from fork sliders. Hook it under the seal and a good jerk will have it out within milliseconds without endangering the fragile slider.
Jubilee clips?nealebms said:Or some thin plastic sheet cut into strips the circumference of the pistons and large jubilee clips.
Neale
Rockitdoc said:What's the trick to getting the pistons back in the barrels after removal? Two ring compressors?
