Hi All,
My Jota America 1200 will not rev cleanly. This is a project bike that sat for a few years when I got it. I did not ride it before I did a few modifications to it, so I did not know if this issue was there before or not.
This winter I :
Completely rebuilt carbs 60 idle 115 main 70 starter otherwise stock internals
Replaced intake orings
Replaced choke plungers
fitted 4C cams
shimmed valves
Put a Laverda racing 3 into 1 on it ( yes I know this is not the ideal pipe)
Installed short velocity stacks
I also did much other work that does not apply to the engine.
When I set cam timing I used the recommend specs from the Laverda mania web site .
The bike will start very easily and Idle all day. It takes throttle beautifully while on the lift . Very crisp and quick. All sounds and feels great. That is until I went for my first test ride yesterday. At anything over 1/3 throttle the bike drops off and is not happy until I roll the throttle back . It is as if I am out of fuel or hitting a rev limiter. This coincides with around 4k rpm .
I ran out of time last night and will get back to it today. I need to do a plug reading and check ignition timing.
Are there any recommended ignition timing specs that will work well with my setup?
Thanks
This winter I :
fitted 4C cams
shimmed valves
Thanks
