If executed correctly, a joint in a brake hose has no effect whatsoever. An ideal solution regarding pressure transfer from lever to caliper would be a solid pipe from the M/C to the caliper/s. As suspension movement needs to be coped for, a flexible connection is necessary. In the end, it all comes down to production costs and what the consumer is prepared to pay for a bike off the showroom floor, the main reason most modern bikes are still fitted with rubber hoses. Of course these will not offer ultimate brake performance, but it will be more than good enough for most of Joe Public nonetheless. Personally, I haven't found any stock modern bike to be lacking in the braking department in road useage. Those that have braided hoses ex-factory also carry a corresponding price tag... Lot easier/quicker to thread a hose through all the nooks and crannies instead of a solid pipe, again reducing production costs.
Absolute no issue with the Laverda factorys' solution with rubber hose/steel pipe, well executed and looks tidy while reducing the hose length as far as practically possible. Correct, rubber hoses have a "use before" date, some T?V tech inspectors take a very close look, which, in itself, isn't such a bad thing, if you think about it long enough. Reckon it is also a UK MOT requirement.
