Yup,
Balance shaft, Counter Balance shaft / gear.
I recon I can modify things to work well, Just got to calculate the exact weight for the counterbalance and where it must be as the twisted twin arrangement adds a spanner into the works because I need two masses at 90 degrees to each other and probably overlapping. I think if I use a big chunk of Mallory metal I can manage to make it quite small and compact. Just up-rated the needle bearing spec to cope with the extra loads and managed to get even better spec than I had wanted. ~Yummie!
The crank gear is 25 teeth and the jockey was 24t so have also just ordered a new 25t to replace it and have to re-calc the idler shaft bore position now.
Fun though.
J
Fun though.
J
