smlav
- Shropshire UK
I have a GTL fitted with SF1 motor, and it has PHF 36mm Dellortos’s which I think came from a Guzzi Lemans. The GtL airbox is gone, and there’s barely enough room for the carbs to fit in the frame, they just touch some of the brackets where the regulator mounts.
I’m planning on fitting something like K&N or similar filters. Ideally I’d like to get inlet manifolds/stubs that have an angle to lower the carb by a cm or two. Is there such a thing?
Is it safe/practical to remove the insulator that lies between the inlet stubs and the head? The rubber boot between carb and stub should give enough insulation I think.
I am going to replace the ancient inlet balance pipe with something which can cope with modern fuels. Any tips for where to get something, can’t seem to see anything on usual vendors.
