Met up with the guys at Nth Richmond .. only 4 out of 5 fronted.. story of the other one having to pull out (hahaha)
some dribble about being due to work commitments...mind you that was before the rain was forcast for the weekend
Worst still his mate had to find out second hand...interesting anyway the social secretary at the Tin Shed got a message off to his the spies on the Nth Beaches
So that meant that there would be only 2 Lav's to Nundle as the other two needed BM's instead of their Lav's ???
Trip to Lithgow was relatively dry, had breakie there it was bit late but dam fine spread .. so then I decided to give the Cico a good run and do the Bylong loop with the others ... then back via the Putty what could go wrong...
Exactly so after we left Lithgow bout 10mins down the road the god dam heavens opened up didn't they.
Cico was struggling to find traction at times....hmm wet roads, cross winds, Pilot Acitves and a big bore Redax torque monster....but it was fun
What a great engine that bike has I am so lucky
After the boys split at Denman to head north I headed for home and it pissed down... Jerry's Plains is closed for gas so ended up going to Broke... from Jerry's to Broke it was dam hard to see where the hell the road was it was so bad. Anyways wet run down the putty at least not much traffic but there were a few skippies hanging around the edges.. which made it interesting. Got home wet but smiling and noted the text from the others as they had made it to Nundle.
the social secretary at work
Where's the dam sun Tom no need for sunnies (bolt)
