Dellortoman
- Tasmania, Australia
Vince said:The only issue I need fixing lately is if my hands get wet they tend to stick to the inners in my Gortex gloves and pull it out when pulling them on and off.
You can fix that. Grab a needle and thread, and put a stitch through each of the finger tips to hold the inner linings. Then when you pull the gloves off, the linings can't be dragged back. A stitch in the finger tip isn't likely to cause the gloves to leak, but if you're worried about that use a dab of waterproofing wax to seal it.
The best way to make sure you sew the liner in the right place is to wear the glove that you're stitching and curve your fingers as they would be on the bike. Leave the stitch a little loose when you tie it off so the liner can move a bit as you flex/straighten your gingers. Just be careful not to jab the end of your finger with the needle. Use a curved needle if it helps. Surgeons should be good at that sort of thing
