R
Reggie3cl
Guest
when I installed RS36s with straight rubbers like you show for your 3c, the petrol tank rubbed on the tops of the carbs. I tried raising the back of the tank up but didn't like the look.
IIRC I raised the tank a few mm by putting a bit of plastic tube under the rubber bungs that support the tank at the back, cos I think I also had a similar problem with clearance. Three mm or so wasn't too noticable once the bike was back together looking at the pics.
I cut down the airbox a little as per Red's instructions, and the rubbers were pushed into the box a bit- to the first 'concertina', but the seal was good. That did push the airbox quite hard back against the frame rails, causing one back to disintegrate. A machined alloy replacement from Ralphie fixed that (the backs are quite brittle compared with the front of the box, dunno why)
I stretched the rubbers with one of Red's carb adaptors- just got it good and warm in front of the fan heater and then pushed the adaptor in, let it cool, then warmed it up again a couple of times- seemed to do the trick. Once they were in place for a while they were fine to fit. My rubbers were quite new and stretchy though- think from Slater's.
My plan was to then go to pod filters and I bought some of Red's angled inlet stubs to do this, but sold the bike before fitting them.
