Thanks again for all the input. Lots of good information here.I really like the swingarm/gsxr wheels, etc- did you have to alter the frame to accept any of it? It should handle and brake better. And are the GSXR wheels any lighter than stock?
I’m away for a few days but looking forward to getting back into the garage
Swing arm fit with no alterations
I’m confident the braking will be improved as should the handling with the larger modern rubber
Very little difference in weight between stock front the stock front rim-rotors and the Metal Gear rotors and Gsxr rim.
On the rear I weighted the new swing arm complete with Gsxr rim new rotor calliper and mount, sprocket,axel and spacers. It was only a few hundred grams less than stock. The Gsxr rear rim is a lot heavier than stock.
