mauricejota7604 said:
So can these head gaskets be used successfully if you retension a few times strainght after each heat cycle?
so it seems the general consensus here is that one should not use these new head gaskets which just happen to be the only ones that are available now
sweet, Keith, Piet and myself can now retire, we don't have to do any more engines because the gaskets are suspect, fantastic
but what do I do with the 27 engines I have booked in at the moment, send them back ?
we need to be a bit realistic here, these gaskets are what we have so we have to make them work
I had issues with some converted 1200 engines 18 months ago where I would diligently machine the 0.1mm recess into the liner after boring the barrels to use larger sleeves, spoke with my main engine machinist who told me to go flush which is what I did and never had an issue after that on the big bore engines
have not had a 1000 engine play up on me yet though there is always time, plenty of new ones running around but no owners have contacted me yet and said their engine is a dud
one thing we do though is we always do a service on a new engine before shipping it off which means we run the engine in our test bench, tune it, cycle it through a run in procedure to seat the rings, check valve shims, retorque the head, run it again then pack and send to the owner
it may be that the very early re-torque of the head is helping us get away with using these head gaskets, time will tell
2 years ago I contacted Cometec and asked them for a quote on getting MLS head gaskets made, they came back and told me that it would cost me $3,500 for the design and tooling required for them to gear up to do Laverda head gaskets, then for a run of 100 head gaskets cost would be $115 each and that after I spent all that money they would not give me exclusive rights to the MLS head gaskets as in anybody could then contact them direct and buy one from them for the same price as I could so there was no way for me to recoup the $3500 set up fee
arseholes, told them to shove their gaskets
