piranha-bro2
- Melbourne
Revisiting this very interesting thread now that the SFQ is only hours away from coming back to life. In my endless frustration with this discrepancy issue between advance on cyl 1-2 last night I did precisely what you did to correct a similar issue, Andy - and Eureka! ... it worked. As you said, it's only a bee's whisker, but that's enough to make the diff. Yet to try it on a running engine, but confident it will be good on the strobe at max advance.Soooo… this may be an oversimplification and a product of my limited knowledge and my misunderstanding of Jon’s explanationsbut if the system doesn’t allow an “advance” correction, for cyl2, could you (or did you try) retard cyl1 ? Then rotate the backplate to suit?
P.S. if you end up adjusting the physical pickup positions, I was able to correct the same timing issue (on a different machine and not Ignitec) by creating a tiny bit of clearance on the backplate, allowing some sideways movement, then I could move one pickup without moving the other. It was a bit of a pain- microns in it- but it worked, and allowed me to adjust it with the motor running and one eye on the strobe.
I don't know whether i blame myself for not getting Ignitech's printed Guzzi pickup circuit board dead centre on my alu mounting plate, or whether I blame the manufacturer of said board for not getting the sensors exactly 135 deg apart (read half crank speed, so 270 at the crank), but the fact is I now have eq advance left and right and can proceed to the next checkpoint. Whew!
