The Sock
- London, England
Enema3CE ....... E for Enigma?
Jim
Enema
The most attractive big motorcycles Laverda made were twins.I`d have thought the money is pretty much there for a clean example of the second most attractive motorcycle Laverda ever produced ........ on a par with a Jota asking - price wise ........ Only downside is that when someone says " Nice Jota mate " , you will have to say " Well actually it`s not a Jota , it`s a 3CE " ............. which should stop the conversation dead in it`s tracks , and result in the interested party wandering off with a puzzled look on his face ........
Only ( other ) problem is , it`s so nice you will have to find another , scruffier , Laverda for everyday use .......... which probably won`t be too much of a problem for someone who has £15.5 grand to splash around in the first place .......
And vice versa, and does it have a certificate and how much is it worth?The motorcycle, in question, is fitted with standard, strangulating silencers, so how is it a 3cE?
If you take a 'Jota' and fit A11 cams, 9.5 to 1 pistons, hideously restrictive collector and a set of those silencers, is it still a 'Jota'?
Or a 3CL?
Discuss?
Viscosity of the oil is always directly related to tyre profile and pressure as well as battery type. I also wonder if we have to pronounce 3CE as E-bike?And vice versa, and does it have a certificate and how much is it worth?
Which oil should I use?
There were examples, back in the day, of a bike sold as a 'Jota', later turning out to have had A11 cams in it. Is it still a genuine 'Jota'?As to the Jota question ........ If you took a bike that started out as a Jota , but then changed cams , pistons , carb settings and exhaust and so on for 3CL parts .......... then yes , it most certainly would still be a Jota ........ just a Jota that someone has been messing around with , that`s all ......... Likewise fitting Jota parts to a 3CL ........ it`s still a 3CL ...........
And what’s this worth?
Full Oro restoration, new old stock frame, stove enameled, new wheels almost everything new. Motor rebuilt.
Yep, I know, it’s not 100% original, but it floats my boat
The factory workshop tools are included.Grinder/polisher included? Can you detach the polisher when you go riding ....... or do you just lean more to the right?
Jim
