Perry
- West Dorset UK
7153. S1.
Definitely LHS, Round cover and 3 screws as you state. It’s got the spider over the clutch drum, lumpy alternator cover on the RHSWhich side is the ignition? S2 is on the left with the same round cover and 3 screws as the 500.
Do you know the full history of the machine?Definitely LHS, Round cover and 3 screws as you state. It’s got the spider over the clutch drum, lumpy alternator cover on the RHS
Like an RGS but the shifter is on the RHS
I’m afraid not, Imported from Spain around feb 1999, I got it a couple of years ago, seems to have been off the road quite a bit since it was imported!Do you know the full history of the machine?
Nope identical!I bet the frame number is different.
Good old Moto Laverda always a surprise to be found show us some pics, or maybe the engine was replaced and stamped to match the frame?????Nope identical!
"S2" is referring to the engine being a different configuration with left side pickups and right side "just" alternator and starter-flywheel). You might be mixing this up with the Frame design, which was changed, too, mainly visible by the forward leaning rear shocks. 3CL's had - from some point in time - the same frames as the 1200's. Yours is a late 3CL which should have the Frame Type 2 (1200 series frame) but still have the (fairly) flat primary cover.Hello
i’m a bit confused now
My 3CL IS 6990 and a s2, at least I thought it was?
pretty sure the engine case was re-stamped... Show us some pics of the engine number, please. I doubt they will have the engine factory replaced with a series 2 engine...Good old Moto Laverda always a surprise to be found show us some pics, or maybe the engine was replaced and stamped to match the frame?????
Here’s the engine number, the inside of the primary chain case as I’ve got it off at the moment and a couple of pics from when the bike was advertised
My 3CL is 4045. If you reckon 6990 is a prototype 3CL what the hell does that make mine ?Wow!! well that stamped number appears quite genuine that's for sure may have been an early prototype 3CL
it does indeed have the lug, what is the significance of the pickle?
