I'm very meticulous about getting A N and E connections right. I've been doing domestic wiring since I was a kid. My dad taught me when I was old enough to use a screwdriver. He was a licenced electrician as well as an electrical engineer. He knew that as a curious kid I'd eventually be poking things into power sockets or taking them apart, so he figured I'd be safer if I knew what I was doing.
I can't remember the last time I wired something incorrectly, but I know it's possible. All it takes is a lapse of concentration, so I always double check installations on completion. I have a test device that I plug into a GPO or extension lead to check that the connections are right. All sparkys will have them, but for the uneducated it's just a simple device with 3 coloured lights that you plug into a socket. Different lights will light up when plugged in, depending on how the plug is wired. There are heaps of versions on the market, some more advanced than others (some have press buttons to do further tests). If you wire your own plug sockets or extension cords, I strongly recommend you get one
and use it. They're not expensive. Here's an example.
