The stock taps (all types) are more than adequate, they will supply 2 litres in less than 10 minutes from a full tank. IIrc, it was around 8 minutes/litre/tap. A little less as fuel level drops. If your bike doesn't manage with that, you've got a whole different problem.
Check taps, filters and hoses for obstructions. Paint chips are especially common. The main advantage of the RGS-type fuel rail is cleaner/easier routing of the hoses, I have never noticed any performance advantage.
I haven't found the repro cube type taps to cause any problems, I've installed dozens without issue.
