Andy
- Auckland, roughly
I thought that was all that was left after you'd extracted the baby oil?You don't want people to think you're grinding up dried babies.
Which was freshly squeezed by a babysitter?
So is it fuel or oil?…….do you turn your fuel taps off? (Best practice if sitting)I may have located it but can’t explain- there’s a drip from the carb float bowl ! Weird.
And quick wiff with the nose will answer that if fingers can't.Sounds like a Smeggy petrol greeny weep
Yep taps off (as normal) I thought there may be some oil in the carb pumps which I’m not familiar with. (I know Amals inside out; literally). Tank off job I suppose.So is it fuel or oil?…….do you turn your fuel taps off? (Best practice if sitting)
is It tracking from somewhere else?
No I cleaned out the fuel system and put the expensive stuff in.And quick wiff with the nose will answer that if fingers can't.
YesOn the topic of oil, there’s an adjustment nut/bolt coming out of the bottom of the primary cover, is it a chain tensioner? That’s weeping a bit too.
Cleaned what? And how?No I cleaned out the fuel system and put the expensive stuff in.
I generally use petrol. Just flush out the crud, new pipes nothing major.Cleaned what? And how?
If you didn't do anything else, you probably have muck in the float bowls, and maybe in the bottom of the tank if your flushing out wasn't thorough.I generally use petrol. Just flush out the crud, new pipes nothing major.
A search on here for “primary chain” will yield lots of info and opinions on adjustments, and take care of a wet Sundaythere’s an adjustment nut/bolt coming out of the bottom of the primary cover, is it a chain tensioner? That’s weeping a bit too
Hopefully.A search on here for “primary chain” will yield lots of info and opinions on adjustments, and take care of a wet Sunday.
Depending on the state of the chain (remembering that chains are cheaper than sprockets and cases) you will need several copper washers stacked under the dome nut. If these are annealed or renewed then the weep will stop![]()
If your primary chain has an unknown history, change it.
Nothing worse than a crying primary adjuster, yes it is a hard life, especially when you smack it on the ground when getting stuck into a left hand sweeping corner.... but crying... its too much.....sic jYep taps off (as normal) I thought there may be some oil in the carb pumps which I’m not familiar with. (I know Amals inside out; literally). Tank off job I suppose.
