hooksey
- Vic , Australia
Well bugger me, i must be doin something wrong...................Sticking clutches is as old as big Laverda motorcycles.
You should try my Falcone.Start with a light solution: Start the engine, pull the clutch and hold it. You probable don't hear a différence in noise. Then give the throttle some light blibs, like 2000 rpm while you still have the clutch engaged. If the sound changes then you can engage first gear.
This works for me , can pick when it frees up by listening.Start with a light solution: Start the engine, pull the clutch and hold it. You probable don't hear a différence in noise. Then give the throttle some light blibs, like 2000 rpm while you still have the clutch engaged. If the sound changes then you can engage first gear.
Hi MonkeyTS, a method I have used before with some success is to start the bike on a downhill stretch of road. Get it warmed up nicely while it’s stationary - feel the crankcase to make sure the gearbox is nice and warm. With the engine still running, release the brakes and let it run down the hill. As it starts rolling hoik the clutch in and hold it in, first or second should now be selected. Keep holding the clutch in, apply the brakes gently and a combination of heat, engine load and vibration should break the clutch free. If it doesn’t work, you havent lost anything…. Maybe even try again!Hi Clem,
Sounds like mine is a series 1 TS ? number 2988. You mention it's a very easy thing to do, if it's a Mk1. Do I need any specific tools to undertake? As I think I'm going to have a go. Seems the value would be much lower, if it's not sorted. Also Is there anything specific I need to be aware of, must do or not do? Before I remove the Primary case.
Richard
Hi RichardHi Clem,
Richard
Is the clutch sprocket bolted on rather than rivetted on that machine?Hi Richard
there are a few "tricks". Getting the crankshaft nut off can be a right prick if you do not have an impact gun. What the manual does not tell you is that you don't have to take the crank nut off at all.
to take the primary cover off, back off the primary chain tensioner (lock nut and adjuster sticking out of bottom of the primary cover) to take any tension off the primary chain.
then remove all the primary cover fasteners, and if it is stuck, whack it with a rubber hammer in several places. It will pop free. Resist the urge to stick a screwdriver or pry bar between the primary cover and the engine case or you can bugger the sealing edge.
with the cover off, ignore the crank nut. You will see the primary chain and the gear on the clutch cover. if the motor is early, move on to next step. If motor is later it will have a support with bearing over the clutch, just remove the three bolts and set it aside. Unbolt the half dozen bolts holding the gear on the rubber isolators, and you can wiggle the gear off the clutch complete with chain. Then you will need a pair of circlip pliers to unsnap the circlip holding the clutch cover itself off. It just pulls straight off, although inside it has a whole bunch of fine splines that the clutch plates may be stuck to. Again, use a rubber hammer to persuade it loose. That's it for disassembly. A brand new clutch set of steels and fiber plates is relatively inexpensive and highly recommended. Soak the new fiber plates in oil for an hour or more before reinstallation.
then the only "trick" on re assembly is getting the new clutch plate teeth lined up with the internal splines in the cover. I use a steel straight edge to force all the teeth into alignment with each other, then gently persuade the cover on with light taps of a mallet. If you meet resistance, don't use force, pull the cover back off and re align the teeth again using your straight edge..
the other issue you may run into is the little "anti rattle" springs on the innermost clutch plates if still fitted. I don't even attempt to refit the anti rattle springs, perfectly fine to leave them off unless you have access to the "special tool" which I don't.
any issues, just ask.
Others here may have different fitment advice, please feel free to jump in.......
Bike will be much easier to sell if it can be test ridden, or at least confirmed by video to run and shift etc.. After sitting for so long, would be a great idea to change the oil, and flush and bleed the brake and clutch fluid, maybe a new battery......while you are at it. Then new tires, then you might as well keep it and ride it........
I once rode an SFC 1000 I'd just purchased near Gothenburg to South West London with a totally inoperable clutch . Well it was OK for the first 100 miles and then the crap in the hydraulic reservoir stirred up by fitting a RAM sat nav mount on the clutch lever perch before departure blocked the return port in the master cylinder , so no clutch , or rather no disengaging the clutch . I only worked this out once home otherwise it would have been an easy fix !thanks for the follow ups..... If the clutch rubbers are still riveted, I still think it would be easier to drill and thread for bolts rather than deal with the crank "jesus" nut if no access to an air impact. However, as I do not have access in western Canada to the UK ILOC tool lending program, I forgot you lucky fellows who can borrow the factory tools including the crank nut removal stuff.....
I also made the assumption that this is an earlier TS so no ignition to deal with in the primary cover
just trying to give a very plain English description for what this admitted novice mechanic, likely with limited tools, can expect.
I am also wondering if any of the UK members who might be close to him might have mercy onb him and drop by to lend a helping hand. For anyone who has done a Laverda clutch before this is a simple quick process, I replaced the clutch in my RGS last year in under an hour start to finish... and if I can do it anyone can, likely better and quicker![]()
Make it to suit. I've used 6mm 'silver' steel and hardened the ends. Don't use 1/4" rod unless you're feeling lucky. Don't use stainless.Anyone know the best way to source a longer pushrod if/when i need it?
