chrisk
- Brisbane, Australia
Maybe they employed him as as per the ad in the paper: Blind hole driller required.
Have a look at the crank before placing an order for pistons.
I reckon a steel sprocket as a tensioner wheel would be better than that crappy looking plastic roller. At least it wouldn't wear as quickly.Yes they start as smooth round wheels with two raised sections to go between the runs of the duplex cam chain. They end up looking toothed after not very long, but I have found that the SFC items with needle rollers in them last far better.
Olly, have you checked the primary drive sprocket on the crankshaft left hand end yet?
I know we can't be certain but so much on the engine looks like it's never been taken apart. It could well be the original bearing. Hopefully one of the laverda specialists out there will have a good replacement for the tensioner wheel. I'm all for something sacrificial - but there are limits!If the chips from the nylon wheels are fine enough to get through the oil screen they can also block the oil hole in the rocker arm and deprive the cam lobe of oil from there. There must have been a reason why the factory used nylon instead of metal, despite the way they wear.
That rh crankshaft bearing looks like the spring from the seal got tangled up in it, maybe someone did a bad seal replacement at some time and ended up with the spring loose in there, they don't generally fall out of oil seals.
Replace a 750 cam chain?Plastic tensioner wheels vs steel: how about
- better damping
- less chain wear
- less vibrations
- less noise
- less cost
Just replace them every once in a while, probably together with the chain.
You may turn a set yourself from nylon or delrin stock, in that case an upgrade to those needle bearings would be a nice touch.
Tom
Yes, 2021 model GSXR.yust a question, how is the material spec. of the plastc rollers, maybe there a more advanced now on the market,
GERMANPOM?
