Schurminater
- Surrey Hills
But thats a Green station Hamish!!........
thanks Paul, just bought a mo.ButtonHi Red
have a look a the Mo Button, you hide it inside a handle bar. Takes all the switching functions from starter button, headlight, horn, turn signals, and brake light activation, and results in only one tiny 22 gauge data wire for the switching functions from the front of the bike to the M Unit.
mo.button
Innovative connection system: Minimizes wiring of handlebar fittings, compatible with mo.unit series. ► Optimize cables nowwww.motogadget.com
they certainly have different names for their products
That rd looks to straight for the sfq.
Bluetooth?I have done the Motogaget thing on my 750SF1 - original wiring was hacked about and I never liked all the connectors being squashed under the tank. Had to run some extra relays to get the headlights working since the ignition switch connects them back to +ve not GND. I did not go M-button but used black cat5 to run it all back to the unit. The thing I really struggled with was the Bluetooth connection - it would work intermittently and never figured out why - I'm an IT specialist and it totally defeated me (and burnt a lot of my time).
Bluetooth has nothing to do with a satellite, just works device to deviceBluetooth?
Does the bike stop if the satellite breaks down?
Please stop adding extra sources of potential trouble on what is a simple machine.
I know, trying to make a point about complicating things whereas it should be a matter of simplifying.Bluetooth has nothing to do with a satellite, just works device to device
the whole point of the Motogadget kit is to reduce the wiring to a few wiresI know, trying to make a point about complicating things whereas it should be a matter of simplifying.
Bluetooth and relays and M gadgets for a thing that only needs a few wires.
In this case Bluetooth is mainly useful for configuration - not required outside of this - although useful for things like checking battery voltage.I know, trying to make a point about complicating things whereas it should be a matter of simplifying.
Wildwood Rd, very straight - had been rolling at 160+ - my birthday last year - battery completely dead, bike stranded, waiting for the towie! I've still got the old rego label inside the fairing screen! Gotta look into where the newie is.That rd looks to straight for the sfq.
Rego sticker lost and found![]()
Paul, relays are a common way to remove problems due to excessive current in switches ... there are MANY tales on here of ignition switches causing intermittent loss of electrical contact, simply because ALL the bike's 12V power supply goes through it.I know, trying to make a point about complicating things whereas it should be a matter of simplifying.
Mine have had broken solder on SF2 and 500. The Bosch switch in the headlight has other problems. If far from home, just twist a couple of wires together, that'll get you home, or even better, use a safety pin through the two wires. Looks less like you've stolen it.Paul, relays are a common way to remove problems due to excessive current in switches ... there are MANY tales on here of ignition switches causing intermittent loss of electrical contact, simply because ALL the bike's 12V power supply goes through it.
Hi Paul,Hi all
I have not been posting much recently as I have been working on a number of non Laverda's. My three Laverda's are all completed and running very well. Have not seen any project Laverda's come up for sale anywhere near me for some years now.......
my last couple of builds have been
- a full cafe racer custom of a 1982 Honda CX 500, full aluminum body work with cafe fairing similar to an SFC 750, Suzuki GSXR 1000 front end, a carb conversion, ignition conversion, and a MotoGadget M Unit Blue with various other MotoGadget bits, and a MAD exhaust, etc.
- a full cafe racer custom of a 1978 Kawasaki KZ 750 twin, aluminum bodywork, carb conversion. Its party trick is a single shock conversion using the entire back end off a later Ninja. It is finished except for the bodywork being out for high end custom paint right now, due to health issues I am no longer permitted to do my own painting, very frustrating.
- currently on my lift is a 1978 Honda CB 750 F single cam, Keihin CR Special carb rack, custom built Hindle stainless steel 4 into 1, Suzuki GSXR front end with Cognito Moto triple clamps, Cognito Motor wheels front and rear, etc. etc., and full custom cafe racer aluminum body work. On this build, the SFC like front fairing does not have a bucket headlight in it. The headlight is being mounted in front of the fairing on extended brackets, sort of like some of the Laverda race bikes of the past.
In this build I am using almost every product MotoGadget sells. The issue with this Honda build is that with no headlight bucket inside the fairing, I am struggling with concealing all the MotoGadget wiring connections at the front of the steering head....... On this build I am using an M Unit Blue together with a Mo Button. The Mo Button is going inside one of the Tomaselli adjustable clip ons, and there will only be a single thin data cable back to the M Unit by the tiny AntIgravity lithium battery, but there is a bunch of resulting wiring connections in front of the triple tree for horn, turn signals, start and kill buttons, the digital dash and the various additional warning/indication lights, the ground wires, the headlight wiring, etc..
As I do not have a headlight bucket inside the fairing to hide the various necessary wiring connections, I have been hunting around for a wiring box to hide everything inside, to be contained within the fairing and better yet right at the triple tree. Everything I am finding for a potential wiring hiding box is butt ugly......
anyone have any suggestions?
and if anyone is going to do MotoGadget stuff on a Laverda, I am happy to help. It has been a significant learning curve.......
I thought about that, but there will be enough space and airflow under the tank. Even in the summer time I never felt an enormous amount of hot air from the engine at a stop. If, but don’t think needed, I have a solution for that. A small duct/funnel can direct cool air. I have seen many builds with the electrical equipment above the engine and carburetor.Very interesting, Hermann! I had thought about putting it there but shied off, fearing, it get's to much heat there. No
finally, we have posts back on subject as opposed to green discussionsI thought about that, but there will be enough space and airflow under the tank. Even in the summer time I never felt an enormous amount of hot air from the engine at a stop. If, but don’t think needed, I have a solution for that. A small duct/funnel can direct cool air. I have seen many builds with the electrical equipment above the engine and carburetor.
Herman
