pf1
- Portsmouth UK
Thanks Lothar, I'll do that.
The settings were probably about 400 C°.What torque wrench do you use, has it been tested and what settings are you using, please? This sounds really weird... Only ever had one or maximum two on one engine. 7 sounds like a fault in the wrench or in the settings; especially if they were timeserted! With Helicoil, I had that, too, several times. but never with timesert...
Lucky really, if they didn’t pull on tightening down, it could have happened at running temperatures which would really fuck your day up, againThe settings were probably about 400 C°.
The difference between tf treated lm9 and as cast or as annealed is massive.The settings were probably about 400 C°.
on cheap ones, that does not help, Paul. I have tested around 50 different torque wrenches over the past 2 years. If you adjust the cheap ones at a certain Nm setting, most of them were way off at other points. Even the semi-professional ones were obviously adjusted to be precise at one range, totally up or down their claimed range, they got more tolerance than in the center of the torque range.Just go to the dealer and get them to calibrate it.
I don't have a cheap one Lothar.on cheap ones, that does not help, Paul. I have tested around 50 different torque wrenches over the past 2 years. If you adjust the cheap ones at a certain Nm setting, most of them were way off at other points. Even the semi-professional ones were obviously adjusted to be precise at one range, totally up or down their claimed range, they got more tolerance than in the center of the torque range.
If you have a cheap one and want to keep it, buy yourself a device to measure the torque settings every time you use it and make sure you "click" it several times before usage. This way you can have accurate settings with a cheap Torque wrench. Everything else is maybe "good enough" but not precise. Just sharing my experience.
That's what I said, no? You said though "just get them adjusted". Quality ones, yes. Cheap ones: just bin and replace them or use them to losen the bolts on your cars wheels when you change them. But else, they are just crap in most of the cases.If you want quality work, use quality tools.
Wouldn't worry too much over that, Pat.Anyway onwards and upwards with the bike. The cam cover was cracked and broken so I dug out another manky one which is taking quite a bit of cleaning up. Even the rev counter drive was seized. Am I allowed to use my cheapo Dremel copy on it to clean the decorative ribs out or is that forbidden? It's coming along though and will look reasonable but it has had some pretty drastic rough sanding already at some time.
Funnily enough the carbs aren't bad, in fact they are surprisingly good, not full of gummed up fuel, no slop in the linkages and there were even two new accelerator pump diaphragms fitted as well as a brand new slide. Unfortunately the slide is a 60/3 and not a 60/2.
I have ordered new K1 needles plus atomisers, main and pilot jets to suit a 1000 engine, the carbs having come off a 1200 originally. I would have ordered them from Paddy but I didn't realise he was still in business and had the parts I wanted so I went to Eurocarb instead. I will need some float valves though because I forgot them.
It's a bit odd that the engine was so badly knocked about and must have been rattling like hell but the carbs, airbox and rubbers look almost new. The slide doesn't look like it was ever used. Maybe someone put them on the bike to try and get it going and then gave up?
