Things that you'll find a bit different...
1. If you changed your login name to a different display name on the old forum, you'll need to do the same thing here. When you do that, YOUR LOGIN NAME WILL HAVE BEEN CHANGED TOO. So you'll need to use your 'new' name for logging in going forward.
2. Personal messages are now called 'Conversations' and are accessed using the little envelope icon up by your username
3. Smileys will not all have been converted across to the new forum.
4. I hoped that old forum links will link through to this new forum. The script hasn't worked. I need more time to investigate...
More after I've had lunch...
