Paul LeClair said:well, in the back of my mind somewhere is the memory of Lance Weil getting killed in his workshop by a lathe......
a small Chinese lathe is not going to do the kind of stuff I am sending out to get made, and a serious lathe is well beyond my experience or current skill set. What I have been intending to do for a couple of years now is to sign up for and take an introductory machining course at the local technical college. I would really like to learn proper basic setup and operation of both a lathe and a milling machine. Once I am confident in both basic skills and particularly operating safety, then I may well go shopping...... I have been following one of the machinist forums the past couple of years, soaking up some information, in very rudimentary preparation
Paul LeClair
Paul,
Much the same skills required for small or large lathes, working principles are the same. Just the max. size of the workpieces differ.
You'd be rather surprised at what a "small" chinese lathe is capable of. I bought one almost 20 years ago. 1000mm between centres, 170mm swing, plus detachable bed for about a total 240mm swing, and it still delivers surprising accuracy. It has served me well and more than earned its keep, and will hopefully continue to do so for a long time to come. I chose this particular model mainly because it turned up at the right time for the right price, but as workshop space is limited, I couldn't have chosen anything larger anyway.
Unless you intend turning your attention to low-volume mass-production, or want it to stay in the family for the next 6 generations, one of these lathes will be more than enough for the odd job needed in restoring old bikes. Automatic feed, thread-cutting, cooling/lube system and spindle brake are standard features these days, a digital read-out simplifies things for a beginner no end! 700-800mm between centres is usually large enough, 38-40mm spindle bore ro rake fork stanchions and a decent swing for larger diametre stuff are things to look out for. Look for one from a reputed machine tool vendor that can offer a bit of after-sales back-up in case parts may be needed (only thing I've needed is oil for the periodic oil change...).
I'm currently looking for a small to mid-size mill, seem to have dropped in price lately.
