Good idea of Red's to use a BMW front end on the RGS frame.
The BMW K75 forks and triple clamps that I bought on ebay arrived yesterday. This morning I put the lower triple clamp with steering stem into the RGS steering head, mainly just to check the the stem length. It still has the beemer's tapered roller bearing on it and lo and behold, the bearing sat perfectly into the outer bearing cup in the frame. That's a bit of a surprise I thought, so I put the top bearing in and it did the same. When I screwed the nut town to seat the bearings home, the internal locking bolt (that I hadn't moved) seated just as the bearing took up, indicating that the steering head bearing spacing is also identical to the Beemer's. The steering stops on the lower clamp also lined up with the stop lug on the frame, and worked perfectly. Even the RGS steering lock lines up with the locking hole in the beemer steering stem!! The bearings move smoothly so I reckon I'll simply re-grease them and use them as they are.
I had anticipated having to make a new stem, lengthen the headstock, find some different bearings, or some other alterations to make it fit together. I couldn't believe it was so simple. Basically a bolt on fit with no modifications whatsoever.
As for steering geometry, I haven't measured it precisely yet but it looks pretty damn close. The Beemer clamps have slightly greater forward offset than the Laverda ones, but the axle is behind the centreline of the forks by about the same amount, so the trail should end up pretty much the same.
The only alterations necessary will be to accommodate a different sized axle. The Beemer axle is 25mm diameter and the bearings in the RGS wheels have a 20mm ID. My bearing book doesn't list a 25 x 42 x 12 ball bearing so it might require some minor juggling to fit the larger axle to the wheel. The bearing book does list a 25 x 42 x 9, or a 25 x 47 x 12, so If I can't find a suitable bearing from another source, I'll either need to make up some spacers to fit the narrower bearings or machine the wheels out to 47mm diameter. I'm leaning towards the former option because the wheel diameter is more than I can swing on my lathe.
Now that I know I don't have to muck about with the steering head, I can get on with the job of frame stiffening.
Cam
