My factory RGS shop manual shows 3 different wiring diagrams for the RGS....slight variations only.
Your regulator looks very close but a little different than the original one on my RGS. Not sure if it is a different factory one or not.
On my RGS and in the wiring diagrams I have, there are no block connectors near the regulator or fuse box. Wires from alternator to regulator change colors at the bullet connections and are located inboard of the flasher unit near the gas tank strap hook. Other than the larger diameter red one that goes from the regulator to the battery it doesn't matter which 3 from the alternator (as long as they are all different colors) plug into those that go to the regulator.
If the alternator wire that goes to the headlight first before going back to the regulator is still as per factory is causing confusion you can leave it alone...its not your problem...going direct to alternator as I said above is just better and simpler.
I have no idea on the aftermarket Ignition you have. But I don't think the wiring mods for it would change the wiring associated with with the charging system.
Thanks for the replies. I’m gonna head out to my shop in a bit and see if I can apply any of these suggestions to what I am looking at on this bike.
This is a 1983 model and supposedly I am looking at the correct wiring diagram that appears to be incorrect.
I will say that to me the harness doesn’t show any signs of being cut and spliced back together on the rectifier or any other connections.
I have been reading through old posts about this problem and have found several references to this rectifier as a suitable replacement;
Kawasaki Motorcycle 1990 EX500 - EX500-A4 GENERATOR. Kawasaki Motorcycle 1991 EX500 - EX500-A5 GENERATOR. Kawasaki Motorcycle 1993 EX500 - EX500-A7 GENERATOR. Kawasaki Motorcycle 1989 EX500 - EX500-A3 GENERATOR.
www.ebay.com
If I did purchase this can anyone provide any guidance as to how to wire it correctly?
As for the wire “going to and from” the headlight switch I will attempt to use the diagram to find that wire and see if I can make any sense of that. I am assuming that not having my headlight plugged in is not causing my problem?
I also still can’t get my head around having only one yellow wire coming from the stator to the rectifier and the other yellow wire that goes to nowhere. In my world I’m used to three yellow wires from the stator and accurate wiring diagrams.
Any suggestions are extremely welcomed and I certainly appreciate your input. I really need to get this resolved so I can move forward. I have several of my own projects I would like to get finished and off of my lifts. As of right now I have Laverda parts all over my shop.
Here’s an easy question. I have heard references to an “Executive” model. This bike has the extensions on the fairing, the solo seat cowl, and the hard bags. Does that constitute an Executive? Does that possibly explain the discrepancies in the wiring diagrams?
