More home truths from the bench and road, one well known RGS rider, barrels removed, reassemble engine, no addressing of piston rings ( reused original high kms ), barrel bores not dressed, assembled, road test engine, smoke machine that would have covered a major outdoor festival.... i did the engine that way, was a long time ago. Went on for weeks the constant smoking while riding, on domestic local roads. Cut to the NSW Laverda Snowy GP as we called it.... after day one of high spirited upper RPM engagement, less smoke, end of day two, no smoke and nice easy motor to ride and idle...
Last motor i did, ball hone the bores, to give some surface bite for the rings, have a great problem with the notion of "glaze" effect in a bore, without insisting upon it being an anomalous term, my perspective is that it is more aligned to a "case hardening" effect than actual "glass/glaze/polish" effect, being high carbon content liners, it is my less than expert knowledge of metallurgy, a limited working knowledge at best. The more qualified than myself may expand on this perhaps. j. *** oh and that motor was perfect, not even a wisp of white smoke, just the first minute or so after rebuild and oil used in the reassembly clearing.
