Fitz
- Cheshire UK
Hello all, hope everyone is surviving the lurgy as well as can be expected
Couple of questions:-
1) Has anyone done a 530 to 520 chain and sprocket conversion on an early SF1, if so what engine sprocket did you use. I did this on my Monty racer, the engine sprocket splines are identical to an early Honda twin, the weight saving is significant and I can use modern chains and have tricky lighweight wheel sprockets made to order. Just took the rear wheel and hub apart on the SF, the sprocket is steel, weighs a ton and has crap machining, the chain could have held the Torre Canyon off the rocks
2) Has anyone done the swing arm bush to needle roller conversion on the SF, if so can you provide drawings or dimensions, again I did this on Monty racer and have details. The arse end of my newly aquired SF is waving around like Trumps hair in a breeze, wheel bearings are ancient so they are going, may as well do these two jobs at the same time while its apart
Any opinions on the Bosch ignition coils, I use Dynatek on my race bike and can't fault them, obviously the points ignition will be going, plug leads etc. If the Bosch are OK I may retain them but if they are suspect (and they are 50 years old) they may go as well. It also affects which ignition system I select, the pick-ups, electronics, coils and leads must work together
Just started looking at the rear brake which is huge, I've not looked closely yet, just ordering the wheel bearings, I can only see one operating cam, it looks like a TLS brake that somone forgot to put a link arm in
I have downloaded a really poor owners manual and parts list, is there a decent workshop manual available for download and a source of solid information
Lastly, I am dreading this one - paint codes for the cobalt blue colour, I found an endless thread arguing about such a lot of bollocks, its just blue, from around 1970
Thanks chums, oh by the way, if you are venturing out for the first time this year, please keep your wits about you, I took my big tourer out a couple of weeks ago and had two near misses, one was just " I knew you hadn't even looked for me you bastard" easily avoided, the second nearly had me off, the classic sorry mate, I didn't see you job, I had a massive headlight and two smaller side lights all switched on and the silly bastard still pulled out one me - give me strength
