pf1
- Portsmouth UK
Olive oil?At least chuck the bits in a tub of oil because if Italian weather does that, British weather ain't going to improve it.
It is throwing out a challenge!!!You bought a 750 Bonneville Maurice! How will you ever live that down?
It looks to have snapped but I will check it again, it can't have snapped at any speed or it would have caused major damage or been spit out down the road I would imagine. The chainguard looks fine for instance but the hub vanes are damaged. I only glanced at the break but it was in the centre of the side plates.Was the chain actually snapped, as in plates or pin broken? It could have been brutally opened to enable the bike to be moved.
It looks pretty grim but as is said, get it apart and see just how deep the rust is, you never know.
Hub vanes also go when the sprocket carrier bearings give up the ghost. Vanes rub against the lower shock nut.It looks to have snapped but I will check it again, it can't have snapped at any speed or it would have caused major damage or been spit out down the road I would imagine. The chainguard looks fine for instance but the hub vanes are damaged. I only glanced at the break but it was in the centre of the side plates.
Or I have seen the shock bolt or nut too long cutting away at the vanes.Hub vanes also go when the sprocket carrier bearings give up the ghost. Vanes rub against the lower shock nut.
That's why the original nut is an extra flat one.Or I have seen the shock bolt or nut too long cutting away at the vanes.
You sookOk the nut fitted is the extra flat one, and the chain is snapped on the side plates near the rivet, it's twisted and tortured and from what I can see it looks like it has jumped the sprocket and become trapped between the vanes and the thin nut, it has actually punched a section out of one of the vanes not just sawn through it.
It is bloody cold out there too.
I can't handle the cold any more Tom ha ha!Come on Pat, harden up
Tom
Go for a dip in the 0-degrees-Kelvin sea - apparently it's fun!I can't handle the cold any more Tom ha ha!
It can be saved mate, I was talking to someone with lots of spares yesterday so it's not mission impossible. The nice thing about the bike is the fact that all the original stuff is there. You probably saw my mouse mat with the Continental Motors SF2 ad on it, one look at that and I'm inspired againYou really have taken on an interesting project Pat, if it can be saved all credit to you
Tom
I'm with Mr. NairnMr Nairn reckons they are infinitely repairable.
I can ride my Bonnieville to work I bet that SF2 wont take you to workI'm with Mr. Nairn. And as per Piranha-bro2, much of what you see may be inconsequential surface rust.
Just be grateful it's not a Bonneville (sorry, Maurice: cheap shot, I know, but take 'em when you can ...)
