After careful inspection of the lower yoke, the stem angle is adequate. Where the bearing rests, the lower yoke has a surface that is uneven, higher in the from lower in the back, to allow the forks to have the offset angle, so basically the stem has an angle with the lower yoke. So the angle that is visible between the yoke surface and the head tube is correct. I will try to take a photo where this is visible.
However, Wolfang told me that Ceriani forks came with different offset angles, 1’5 is correct for the 3C. For example, the ceriani fork of my SF3 has no offset angle, and the bearing rests totally flat with the lower yoke.
Unfortunately, and as usual here, Piet is correct, all leads me to the fact that the frame is slightly bent. Will fix it some day. For the time will try to avoid the contact with a stiffer fork spring. I bought the one from Wirth, it cannot hurt, and my springs must be worn after 50 years service… the impact happen when the fork compresses 110mm, if I can reduce it to 100mm that would solve the issue.
