Starting my 1000/1
Dellortoman said:
This thread is turning into a Monty Python sketch.
My bike had rotted for 20 years in a salty bog before I started the restoration ...
20 years in a salty bog before  you started the restoration ?
Luxury?.
I found mine in an old water tank at a rubbish tip. It got covered  up every morning by having a load of rotting fish dumped all over it ?..
But you try and tell the young people today that... and they won't believe ya :LOL: :LOL: :LOL: :LOL: :LOL: :LOL: :LOL: :LOL:
Well,
regarding this topic, I have solved most of it. Now I know that the starter solenoid shouldn't be there, as the starter relay, and I was lucky to find an original starter relay. Maurice was very kind and was showing me on a video chat the positions of all relays in his Laverdas, very helpful, thanks Maurice.
So basically is all clear. But I found that the rectifier was changed for a "fagor" one, from a fridge??!!, and I would like to install an original one, or replica? but I couldn't find any or how they look like. Any ideas where to find a rectifier for the 3C? what must be its specifications? i saw on Damm that there are many different ones... My electric knowledge is close to a primary school kid ::)
Miguel
michipons said:
Well,
Miguel
Hi Miguel, here you can see the original rectifier: https://www.laverda-paradies.de/article-49-40A-de.html
Ciao, Gert
After so many issues with Laverda-Bosch electrics I only can tell, make it on modern Ignition and Charging system, so much difference, having a working generator with charged battery and allways the right spark ignition! There is so much time wastet to search for problems without solution...
Hi Miguel, if you want a original build up you have to buy a original rectifier. But a very nice solution is this rectifier/regulator combination. You can mount it easily where the original rectifier is mounted. With this regulator you can use a Hawker battery also.
https://www.kickstartershop.de/en/rectifier-regulator-12v-15a?language=en
Ciao, Gert
Ciao, Gert
Hi Gert!
Thank you for the info!! Do you mean that this modern rectifier will have better performance as the old one? Do I need further changes in the electrical system?
Sounds like a good cheap solution.
Hochkoening,
Yes I am quite sure your are right, but I need to restore the bike original and have it working, thereafter I will consider modifications, otherwise if I start changing from scratch, the project becomes difficult for me, as I don?t have previous experience...
Miguel
michipons said:
Hi Gert!
Miguel
Yes, better performance because it is not only a rectifier, but a regulator also. Some of my friends and I had good experiences with it mounted to 1000/1200 triples.
Ciao, Gert
michipons said:
Hi Gert!
Hochkoening,
Miguel
Well, this I wanted on my last Projekt also, ignoring that the HKZ is 40 years old, also the generator, what was rubbish as new allready! And the time matters!
A recifer cannot perform any better, since the power comes from the generator....
Ciao, Gert
Hi!
I have been looking to start buying some parts of the electrical system, and I am considering to buy this rectifier/regulator, with the idea of installing a AGM battery as Gert suggested me. (Why do I need a regulator for an AGM battery but not for a lead-acid?)
You can see the rectifier in this link:
However this rectifier has only 3 pins, when the original has 4 (+1 earth) and the replicas also have 4 (earth housing). Looking to the electric schematics, of the rectifier, outer pins goes to the phases of the alternator (which colours?) and the middle one goes to the battery. The original schematics have another 4th pin that goes to the fuse and to the ignition key! So how do I have to modify the system to adapt this rectifier/regulator?
I attach my bike electric map so we are all on the same page.
Miguel
AGM and lead-acid batteries use the same chemistry. AGM is actually a lead-acid battery, but is constructed differently from the old wet cell type and is much more compact.
The reason your 3C didn't have a regulator originally is that the alternator output was small, and the old wet cell battery was massive. The huge battery provided a sort of regulation function itself.
For similar cranking Amps, a modern AGM battery is much smaller than the original wet cell battery, so it is less able to soak up voltage peaks. A regulator is a good idea in that case to prolong battery life.
Re the small RR you were asking about: There has to be a minimum of 4 connections - 2 for the alternator input (doesn't matter which way you connect them), A positive feed to the battery, and an earth. If there's no earth pin, then it must be earthed through the housing. You'll need to make sure the RR is suitable for a negative earth system.
Hi Miguel
The item you linked to is suitable for the alternator on your bike, although I have no idea how reliable it is.
In the description it tells you that the outer connections go to the alternator (it doesn't matter which wires - yellow and yellow/black originally - to which connection).
The case of the regulator/rectifier needs to be connected to earth - the mounting bolts will do that for you if you use a metal plate connected to your frame.  If you have any doubt, run a wire from the mounting bolt to battery -
The centre tag on the regulator/rectifier is the +12v feed to battery, fuse and ignition switch.  So you need to connect a loop to do this or run another wire from battery +  Use 3mm2 to minimise volt drop
Congratulations of firing up your 750 - a super feeling!  8)
Ok, I see. Well, the specs of this rectifier that Gert recommends, says that the housing is the earth to the negative of the battery. But I still don't know where to connect the ignition key cable and the fuse that the original has connected to the rectifier, according to the wiring diagram.
But if it is as Maurice says, that my alternator is a single phase, then I can't install this rectifier/regulator, isn't it?
I would like the AGM battery because of more starting power, less maintenance, long life.... but of course, I can always leave it original :LOL: :LOL:
You see, everytime I try to change something, 100 additional problems arise ::) ::)
Miguel
Rob said:
Hi Miguel
oh, great Rob! understood! all clear now, thank you! (until I start assembling... :LOL:)
yes, amazing feeling, I need more now :LOL:
Miguel
Years ago made the mistake of an Odyssey AGM battery on my single phase 1200,it"s only in the small print they state not suitable, as Keith Nairn pointed out to me, I use a 30ah Numax ride on mower sealed battery now on all but my 120 RGA,thanks to the suggestion of Alan Bell, and yet to replace them.
Not suitabke because of the single phase?
And sorry, Indidn?t understand, what batteries are you now using? Sealed gel type?
Miguel
this is what a genuine factory fitted two phase reg/rect looks like, they are no longer available, this is only the second one in 40 years that I have had on my bike (TOG) and at least 210,000 kilometres, with plenty more not recorded.
it is the finned aluminium box at the bottom, the fuses and carrier are not original but EXTREMELY worthwhile as the currently made torpedo fuses are not good at all.
