Laverdalothar said:
You obviously never faced overflowing carbs due to a float that stuck open, right?
Wrong. That's a rather pompous comment Lothar, and not an obvious conclusion at all. I've been around bikes long enough to have had problems with overflowing carbs on many occasions. Especially with Keihins for some reason. Perhaps I've just been unlucky with them.
Opening the fuel taps and giving the carbs plenty of time to overflow, then checking that they're OK is an essential pre-departure safety check in my opinion. At least then if you have a stuck float you'll be aware that it's pissing fuel out of the overflow before you start the bike. If you ride away unaware that a float valve is stuck open, you run the risk of the bike bursting into flames somewhere down the road.
Bazzee is correct. My bike now has Mikunis, but that's not relevant. I use the same starting procedure with any bike. I've done it that way since I was a teenager and I witnessed a mate's bike catch fire because of an overflowing carby.
Laverdalothar said:
If the bike needs full choke, I would check the choke sliders are all on the same level and are opening and fully closing the same time. If that is the case, you might be running lean on your bike, maybe float-hight a bit low...?
I suppose I could throw the converse argument back at you. If your bike doesn't need much choke for cold starting, then perhaps the idle mixture is too rich.
Pretty much every bike I've ever owned needs choke to start from cold, even when everything (including float height) is set correctly. That's what chokes (or enricher jets, or ticklers) are for.
Rather than apply choke gradually while cranking the engine on the starter, I just give it full choke to begin with. That may be more choke that it actually needs, but it starts straight away. Once it's running, if the idle is a bit fast, I'll back the choke off a little. If it's a warm day, sometimes I can back it off all the way.
