Legs
- Adelaide Hills
Was taught that was standard engineering practice.the head should be "let down" from tension in the reverse order to "torqueing up
nick7 said:and one of your timecerts aint straight btw, so will be redonemaybe.
tom3c75 said:Gently Bentley when separating the cylinder head from the barrels.
The front plastic cam chain guide often breaks at the locating pegs (top or bottom pegs, can't recall).
Item 40 on the attached PDF parts list.
Tom
Paul Marx said:Wouldn't that be changed as a matter of course?
TheWrongTrousers said:Sounds like I may have to add that to my growing list
mcnicol said:If you're going to go with Paul's advice and use a rattle gun (electric or pneumatic) you will need an extra long 38mm socket for the nut behind the alternator, they're a bit hard to find. I recommend just looking for Grey Pneumatic 2036XMD on line.
Pretty hard to do without a rattle gun, in fact.
Ken
sfcpiet said:Probably easier to make one than to buy.
mcnicol said:Oops. Part number's right, though. Got it here in my hand.
Ken
Paul Marx said:Not certain that the commercially available long sockets will work because they won't allow the crank end through. They are obviously thicker than 36mm along the shank.
The ideal way would be the factory way, block the crank using the woodruff key and a 36 mm spanner on the nut.
Since I was in the same situation last week, a box spanner was suggested, ordered and paid for but not received yet.
You can also try to use the alternator to block the crank with the lh 32mm crank end nut whilst you undo the 36mm nut turning it clockwise, or use the two small holes on the alternator plate to block the crank.
The nut on my engine wouldn't move so I ended up cutting out the oil seal behind the nut and using a grinding tool on a Dremel to cut the nut without damaging the thread on the crank. Rather extreme, but it's off and will proceed with measuring valve caps today so as to take the head off.
