I'll start it off.
Laverda 750 Combustion re-shaping.
As standard the SF head has a pretty poor combustion chamber shape for very high levels of power, It flows fairly well but in order to get a good compression ratio you need to have a large dome on the piston, thus causing obstructions to the flame travel and slowing the combustion down to an extent that you need large amounts of ignition advance and therefore loose power and bring on the likelihood of detonation occurring.
You also have a large combustion chamber surface are that causes heat problems. All bad things.
Solution.
Close up the combustion chamber to make it as small as possible without obstructing inlet and exhaust flow,
First I did some experiments by raising the valve seat into the combustion chamber and found that flow would go up the longer I made the straight "behind seat area" so then filled in the rest of the chamber with epoxy (this is just for experiment)
Problem, Then found that although better in shape it was unworkable as the valves would hit at about 4mm lift on overlap and I was intending to have a lot more. (Full race engine)
Solution, change the valve included angle to move the heads of the valves apart and to allow an even longer "short side" to the inlet and exhaust port, Flow went up again and valves would not hit each other even at full lift. (look at the space between valve seats in the pics)
This also meant that the combustion chamber was now 11mm shallower than before so even less combustion chamber surface area and more squish surface area. Meaning I could run a higher compression ratio with only a very minimal 3mm high dome on my 88mm diameter piston.
In the end I have a CR of 13.5:1 with a 2.88 mm domed piston and 9mm deep pockets for 43 and 36 mm valves
The rest of the head mods to follow in another post.
PS,
Don't test on the flow bench with Plasticine, flow benches eat it
