You may have noticed that the large majority of gaskets as supplied by Athena and Centauro are made from Reinz materials. Reinz and Elring share a large part of the european automotive gasket market.Perhaps somewhat random comment, but I was just checking some gasket materials.
I have found that perhaps the best cylinder lower end gaskets for triples has material Victor Reinz AFM 22 1.00mm thick.
Not sure if the same applies for 750s.
Just bought a similar kit than this one at my local shop. One of the sheets on this assortment is Victor Reinz AFM 22 1.20mm thick. The size is 500x300mm, not A3 as stated (A3 is 420x297mm):
At least several of my local suppliers are offering the same gasket paper assortment.
-Jouni
I've aquired a laser cutter for the sole purpose of cutting gaskets. Not necessarily Laverda, as these are mostly readily available, but those that are no longer made for my Matchless. These produce off-cuts large enough to supply me with the smaller Lav gaskets until I croak... Paper gaskets are no problem for the 30W laser, don't think it will manage to cut the steel sheet reinforced stuff that is used for the Lav cylinder base though. Reckon I'll just have to modify stock gaskets for this engines' 12mm cylinder studs.
