Paul Marx said:You're right Piet, there is a special event in 2021.
The Guzzi centenial.
sfcpiet said:What's Guzzi? :
we use them for water pumps in the North of EnglandPaul Marx said:An Italian bike manufacturer with a tradition, still selling bikes.
sfcpiet said:Reckon it's a bit moot to speculate over what let go first, rod or piston.
chrisk said:What a mess. You have a hell of a job ahead of you.
Did you pick up all the bits to put Humpty back together again?
Jo said:Guess gasket surfaces (e.g. cylinder base) could be challenging to refurbish after the welding is done. How will you approach this
(I know you are good with a straightedge and an arkansas stone)?
8)
In what details such an SFC case differs from a std. one ? always thought just the innards would be unique ..?
hochkoenig said:Sorry for that! A good Welder can do the Job.
"Works-Engine" means a Racing Engine? Looks like somebody has Ignore the "Works-Instructions" of Fixing up the Engine.... The Duration on a 45 Yrs old Engine on Racing is not forver.... Espacially when there ist not enougt Oilpressure like on that, as you can see at the Blue Crank.....
Anyway, I got the verry same on a Honda RC45....
