Laverdalothar
- Germany
OK - here you go... I tested it and - as already assumed by you and Pat, it is surprisingly accurate! That said, mine goes up to 200Nm/20mkp and therefore the scale is in 10Nm/1 mkp steps. Everything between the 10Nm steps is guesswork. Adjustment is subject to the pointer of the scale being accurately at 0 before you start. easy to adjust that way though.I don't reckon there's much that can go wrong with that type. I'd be surprised if its calibration changes.
I still have an old torque wrench that's even less high tech. It just has a scale and a pointer on the handle. The handle deflects as you put force on it and you read off the torque on the scale. It's about as simple as you can get, and it works both ways. I can't imagine how it would ever lose its calibration during normal use.
so - good for fastening the tires on the car but not accurate enough to fasten a Laverda cylinder-head...
