I've fitted Vee Rubber inner tubes for quite some time, no issues at all. They look sturdy and well-made, and still look OK when they're replaced at the next tyre change.
Rims for type-type tyres are generally not air tight at the bead seating, sudden deflation causes immediate collapse. Even a small puncture from a nail can cause the tube to split, depending on tube quality. Tubeless-type rims are generally air tight at the beads, a sudden deflation due to a simple puncture is far less common, the tyre has to be slit wide open for a sudden deflation.
Because the Laverda cast rims have a too-large diametre at the bead seating to start with, the tyre will mostly stay in place after a sudden deflation. It's also the reason they're a bitch at tyre renewal time. IIrc, Keith once modified Laverda rims for tubeless fitment, forming the "safety" hump for the bead and generally allowing for easy/normal effort during tyre fitting. Only way to go, imho...
As already stated, thick, enduro-type tubes will not protect you from puntures, they are only a bit more resistant to pinching due to the low pressures used in off-road use. The weight penalty alone and all ensuing disadvantages rule these out for road use. Waste of money...
