RCGBOB44
- Coulsdon,Surrey, sometimes Germany
I've been using a More and Wright micrometre for years and never had a problem with measuring shims.
AndyW said:Apologies, I guess I must've been imagining things again: I wish the trip through to Bellingen (and back again) a few years ago with *1588* in the back of a ute due to closed up clearances after only 1000km had been imaginary too along with Red's readjustment of shim clearances both ways to Cosi's place (and that's not so far from Brissy as Townsville is) the following year. *1173* barely made it from Townsville to Proserpine and back (700km round trip) before displaying the now familiar symptoms of diminishing valve clearance. In much of QLD and also South/Central Australia generally it's hard to 'cane' a Lav without losing your licence due to the wide open nature of the roads. EG it's possible to cruise along at 110-130km from one fill up to the next without even changing gear... I don't think this really does the older valve seats (mb valves too) any good: word on the streets of Southern Victoria seems to echo this sentiment..
sfcpiet said:If the valve seats in the head skull remain untouched, clearances will stay stable for a very long time. Re-cut seats will recess quickly, this slows down/stops once the seat surface re-hardens a bit. Wider seats will not recess as quickly as narrow ones, but are not as good flow-wise.
When guides are replaced, seats generally need re-cutting. Good time to decide which way to go. Shim sizes are usually in the lower range by now, valve seat inserts restore these to as-new with the possibility to optimally configure the seat angles. Shorter service valves with re-cut wide seats restore some shim size but with sub-optimal flow characteristics.
Nooooooooooooooomichipons said:Now I was thinking... If I make new valve seat inserts... I can put new guides and then I have a lead free engine???
Miguel
we have winters too over here so maybe it's constant throttle they don't like. Pretty sure most folk over here have swapped out their early for later heads in order make bettter/more use of the older models.pf1 said:If the bikes were all as bad as you say yours are then no one would be able to use them. I'm not lying about my old 3C but maybe it's the heat in Australia that does for the pre oil cooler bikes?
I think Slaters used to be able to organise that: not sure if Richard still offers that service ???michipons said:Now I was thinking... If I make new valve seat inserts... I can put new guides and then I have a lead free engine???
Miguel
pf1 said:The problem with messed up cylinder heads and unleaded conversions goes back years. If you want the head doing send it to Piet or Keith but it doesn't need refurbishing yet. As Bobsol said it won't need attention for some time to come. Many heads have in the past been worked on and rendered scrap as a result.
Paul Marx said:Do not give a triple cylinder head to somebody not used to working on them.
motoddrob said:Ditto,
Sent my head to a guy who was the MC engineer expert in Perth. Guides, reface valves, ceramic coating, Came back soft in the area of the r/h exhaust area of the cam bearing.
The ex. cam was binding after torquing down the cam blocks. A straight edge across the top face showed that area was no longer flat. Shimmed the block up so the cam ran freely,
100 kays later the cam was binding again. Sent to Red who faced the top surface and supplied taller cam blocks but that area just collapse again resulting in a binding cam again.
Solution, replacement head. That original head cost me in excess of 2000 oz$$$ and now it's a door stop.
Prior to the head refurb it had gone 45000 kays without needing a shim change
The point being, don't trust anyone unless it's Red, Piet or Keith.
michipons said:Hi!
How do you measure the valves shims? all my Palmer (micrometer) are too thick to go in them! I thought about making a thinner rod/bar with an exact meassure and then extract it from the total measurement, but may be you have a better and more accurate solution? where to find a micrometer slim enough?
Are those shims specific for Laverda, or can I find them somewhere else? They are expensive enough for not having private stock of a few for each measure, but making an order to usual Laverda dealers for just a couple of shims... is a bit tedious.
Miguel
Have a nice weekend!
