- Calgary, Alberta, Canada
Hi PaulAny idea how many splines?
Knowing that, you can work out how many degrees a move of one spline entails.
as I did not understand the significance of the fine splines, I did not count them. When you take the 175 engine apart, when you lift the crank out of the case you will see exactly what I am poorly trying to explain. There is a long thin rod with thin splines on each end that is inside the hollow of the crank end and connects the crank to the lower gear assembly. Not a very substantial rod at all.
I bet the 175 and 150 are identical. If you get deep enough into the 175 engine that you pull the crank, would you mind counting the fine splines on each end of the rod and reporting back? Thanks. I am not overly keen to split the cases yet again just to count splines..
