You would have to make one. Not an off the shelf item. We resort to stepped keysteel keys for mismatched components.How much drama would finding an offset Woodruff key be, you never know till you try.
Thanks Paul.Hi Paul
best online manual resource I was referred to is https://www.rpw.it/Documentazione.htm I just checked, there are a couple of 175 manuals, and cam timing in the 175 manual seems to me to be exactly the same as my 150, but have a look for yourself.
Paul LeClair
Thanks Paul. I've been following this thread with great interest.Hi Paul
sole tech challenge was the cam timing, everything else was straightforward and self explanatory. The only dis assembly issue was pulling the 8 or 9 blind bearings, I broke two pullers on the smallest/shallowest bearing. Resorted to welding a bolt to the stubborn bearing and attaching the bolt to the puller. All the bearings were readily available from my local transmission bearing supply shop from stock.
Check the valve stems for wear from the odd collet arrangement and the extended collet groove in each valve stem. On my engine neither valve could be rescued because of collet damage to the valve stem.
If I had known good cam timing from a running engine, I would probably confirm cam timing from lobe centers before splitting the engine cases, then mark before dis assembly. There were no timing marks in my engine.
Have fun.
Paul LeClair
Classic!We once did it successfully roadside with toothpaste and salt as lapping medium, had to take it in turns either kicking or holding the flywheel, but we cheated, Vince, and took out the spark plug.
A lot of engines run well with the cam timing set to equal lift at 4 degrees (crank) btdc on the exhaust stroke.after mulling Gilera crank/cam timing over in my head the last several days (don't I lead an exciting life) I came to a realization.
on dis assembly and re assembly of the engine I had noted to myself that the crank is finely splined to the internal drive gear with with a rod. Thinking on it now I have just now realized that results in the crank being very finely internally adjustable to the cam gearing..
In plainer English, I had looked at the arrangement, thought isn't that strange, and had not realized that the timing between the crank and the intermediary gear can can be adjusted very finely by simply lifting the crank on the very fine splines, and moving the crank a tiny little spline at a time. No excuses for not figuring it out, other than I simply did not know what I was doing going into this cam timing exercise. Now I have some basic understanding, it has become rather obvious at this very late stage what the fine splines must be for..
bloody hell - now I have figured it out, all I would have to do I set the cam exactly where it needs to be in relation to TDC, then lift the crank off the very fine internal splines, and set the crank down on the fine internal splines at exactly TDC... very clever 1950's Italian design, bloody hell, went right over my head. Now I have to decide if I am going to spilt the cases again to get exactly 106/106 or leave it as is...?
I will see if I have photos showing what I am trying to describe,, but bottom line is none of this is described in any manual I found, I guess 1950's Italians just knew this sort of stuff and there was no need for any explanations or any sissy timing marks......![]()
You will have plenty of time during the Moto Giro to mull it over!after mulling Gilera crank/cam timing over in my head the last several days (don't I lead an exciting life) I came to a realization.
