helicopterjim
- near Lone Butte, BC, Canada
They have an outlet in Kamloops too. Might check on that sometime. I have some brake pads to replace soon.
Jim
Jim
while I am assembling, next on my agenda is to find/source a basic efficient complete wiring diagram for my 12 volt conversion. Need a taillight running light, a taillight brake light triggered off a brake switch only from the rear brake, headlight high beam and low beam, a horn, and an ignition switch. No battery. Will run LED's for headlight high/low and rear running and brake lights. The VAPE 12 volt charging/ignition system appears self sufficient other than I need to tie its 100 watt output through an ignition switch to the various lights required. I do not require turn signals.
anyone aware of a good source of a basic wiring diagram? I have been Googling and there are a lot out there, problem is I am so electrickery deficient I don't know if what I have been looking at makes sense or not....
The fellow from Fleet Brake just called, my new brake linings are installed on the shoes, clearanced to the drums and ready for pick up. Fast turn around time.
