Dellortoman
- Tasmania, Australia
I'd have thought neatsfoot oil or Dubbin would have been better for your boot than Penrite Enduro.I also changed the oil to Penrite Enduro ...
Hard to believe Paul! But nice to hear that you obviously didn't lose your jolly mood!Hung up my calendar which arrived yesterday.. Had to get it sent via the UK , it left there Feb 11th.
Better late than never. A lovely piece of work and great pictures.
I know, but you’d think the fucker would fit, as intended. It all looks logical, but ...Surely welding an 'up' stop lug onto the frame or stand won't be difficult?
Please note that there were 2 types of V shape stands, one for the last drum brake SFC and one for the disc brake models, as in the drawing. The latter is not suitable for mounting on SF frames unless you modify it heavily, so it’s the (11000 batch) type stand that you must use.Test fitted the SFC stand using Wagner’s components..... and fit it doesn’t.
With the mounts positioned so the stand is down, leaning slightly forward. The up position..... which should be almost parallel to the seat tubes, it isn’t by far, and points upwards about 35 degrees and the spring holder is hitting against the cross tube.
Curious....
Double checked the drawings and nothing is missing.
The down rebate is fine and rests against the cross tube, but the up rebate is miles away from the cross tube when the stand is in the up position.
Thank you. That’ll explain it.Please note that there were 2 types of V shape stands, one for the last drum brake SFC and one for the disc brake models, as in the drawing. The latter is not suitable for mounting on SF frames unless you modify it heavily, so it’s the (11000 batch) type stand that you must use.
Marnix
Did you give your SFC a run ..?The LCO Race Section had a nice long weekend on the Spreewaldring race track south of Berlin.
The racetrack is on a former Russian airfield, that was back then in the communist eastern part of Germany.
Plenty of time for good conversations and celebrations.
It was cold at 6 degrees at night and sunny and hot during the day. Our bikes and riders didn't have the slightest breakdowns.
View attachment 57562 View attachment 57563 View attachment 57564 View attachment 57565
Thomas aus LAU
Did you give your sfc a run ..?
Cheers, Jo
And that, my friends, is always good news ...<snip> Nothing fell off.
