Tippie
- Dr?bak, Norway
Yamaha still make musical instruments. It was a standard trick to use the horn button as a kill switch on proddy two strokes back in the day for full throttle shifting.
Using the kill button goes waaaay back. The early speedway bikes using the Binks Mousetrap carb had to use it to throttle off as once you'd pulled the string on the mousetrap it was full open - all the time. Probably learned it from early aircraft which were controlled on the cutout button.I bought a bike of a mate of mines brother, Robin Denny, he gave Yamaha their first win in Europe in 1963 on a TD.
He had a kill button on the handlebar so he could change gear without shutting throttle or using the clutch- so probably had the first quick shifter as well!
Yamaha logo is of course three tuning forks ( not swing arms..) they use tuning fork on cylinder head to indicate the correct R.PM. for noise testing on grass / speedway bikes.
That seems very unliklely to me. But I've never used a tuning fork for anything so what would I know?they use tuning fork on cylinder head to indicate the correct R.PM. for noise testing on grass / speedway bikes.
Ha ha. I once worked for a government department that paid some tosser graphic art consultant to come up with new corporate colours. It wasn't a new logo or anything that required some thought, it was just choosing colours. I think he chose red and grey, then submitted an invoice for $10,000 for his artistic talent. The fools in management paid it, thinking they were getting a good deal. FFS, you can get a Dulux colour chart from Bunnings for nothing.To think that people are paid good money to produce such drivel, think most of them work for political parties.
I have been sound tested at a grasstrack and that was the method employed in a field in Kent, the motor was revved stationary with the forks on rocker cover of my Jawa, the decibel metre was held by the rear wheel - 1992. testing was carried out by the A.C.U.That seems very unliklely to me. But I've never used a tuning fork for anything so what would I know?
Here's Yamaha's own blurb about their logo:
A tuning fork is a tool for tuning musical instruments. It was invented by a trumpet player named John Shore (1662-1751). The tuning fork is composed of a handle attached to the center of a U-shaped steel rod. By striking the rod, sound is created, and the frequency of the resulting vibrations per second is used as a standard for tuning a musical instrument. The three tuning forks of the Yamaha Logo represent the cooperative relationship that links the three pillars of our business -- technology, production, and sales. They also evoke the robust vitality that has forged our reputation for sound and music the world over, a territory signified by the enclosing circle. The mark also symbolizes the three essential musical elements: melody, harmony, and rhythm.
The wall of death Indians use a kill button as well but I’d not heard of anyone using ignition interruption as a means of full throttle clutch less changes. I had to fit the prototype of the quick shift that Fogarty used - it used a variable resistor that converted the distance the gear lever travelled into a resistance value, you worked out the values of the initial pressure/ full tension on forks and drum and set the cut to a value so many percent before the upper value.Using the kill button goes waaaay back. The early speedway bikes using the Binks Mousetrap carb had to use it to throttle off as once you'd pulled the string on the mousetrap it was full open - all the time. Probably learned it from early aircraft which were controlled on the cutout button.
I've been told gearchanging on the cutout was in use pre WW2. It was certainly common in the 1950's. The brakeless US dirt trackers used it - as did our mile and half mile grass bikes.
That rpm check on bikes with no tacho is clever. I'd have clipped a battery powered tacho onto the HT lead.
Dyno testing proved interesting as the cut time had to be altered because of the drum inertia keeping the gear train tight. The Boffin who designed it had a version on his Peugeot estate and had never ridden a motorcycle.
Yamaha used the tuning fork logo decades before it used reed valves.Here's the background to the Yamaha MC three-tuning forks logo origin:
Yamaha instruments refined the vibrating metal reed technology for use in their musical instruments, particularly the organ keyboard. When they moved into motorcycles, they carried over the advanced reed capability to create intake and exhaust valves using metal reeds because they were so fast with negligible inertia opening and closing. An example of this reed valve can be found in the Yamaha RD350 two stroke. I owned one and when you got those valves on song in the narrow torque band it was bloody fast!
For centuries before the tuning forks, Yamaha used another logo ...... tuning chopsticks.
