Nice neat wiring job Chuck. Beautifully organised and tidy. You've almost inspired me to do a similar tidy-up of my Jota.
But again, I wouldn't have used those red crimp terminals. I'd have just tinned the ends of all the wires with solder and shoved them into the screw terminal blocks without a crimped-on fitting. I admit that I'm heavily biassed by a pathological hatred of the damn things, but there is logic behind my argument. By using those crimp terminals you've introduced another joint in each cable that could potentially give trouble. The fewer joints you can get away with the better.
I've been converted to ferules/bootlace for such jobs. Use them at work all the time.
Ferrules are OK, so if they're soldered on. I just don't like those pre-insulated ones.
The bootlace ones that I use are crimped at the bare metal end, not through the plastic. They’re good to protect thin flex strands from the connector screw, and stop the strands from spreading.
Solder tinning (without ferrules) is good too 👍
I can understand your bias toward soldering , but a properly made crimp can be made quickly and will not introduce more dis-similar metals leading to corrosion or oxidation. A good crimp will also take advantage of the insulation for added support against flexing and strain. The blade terminal can be re-connected without degrading.
A good quality crimp tool makes all the difference.
Quoting....
"For cable connections, crimping typically outperforms soldering for a few key reasons. First and foremost, cable connections last longer when they are crimped because they are protected from the intrusion of moisture, dirt and debris. Crimping tools are designed to create an air-tight seal between the cable and the connector. Therefore, moisture, dirt and debris won’t be able to reach the crimped cable. Soldering, unfortunately, doesn’t offer this same level of protection."
There is a reason why aircraft and automotive manufacturers use crimping as standard.
Here's a pic the extracted teeth 😉 .....
My blade strips lasted 45 years on the SF so I couldn't resist using them again in shorter sections under the tank with new crimped blade terminals for the Q. Plus some Deutsch connectors in the mix and other block connectors. I think I'll go with someone's recent recommendation on where to get good solid 6.3mm blades - commercial grade 240V electrical terminals ... Utilux if I can find them.
Quality tools are necessary for any job. I like to solder after crimping because I've found that the wires can pull out of my crimps. Maybe my crimp tool isn't up to scratch.
For small electrical cables I use the crimping pliers in the photo below. They're for non-insulated lugs, and I use the soft type insulating sleeves that slip over the lugs after they're crimped. I bought the crimper donkey's years ago when it was the best I could afford at the time, but looking around on line they seem to be a bit low tech compared to what's available now at reasonable prices. Perhaps it's time for an upgrade. What kind of crimper are you using Chuck?
Cabac HP2. Great for everything so far except the Ignitech miniscule pins - I'm going to see if i can get alternative smaller jaws for it - they're removable so I assume you can fit different inserts.
Get a decent quality ratcheting crimper. The ratchet feature ensures the jaws are closed all the way home. The Cabac ones (such as Quentins) are fine for crimping ferrules/bootlaces, although I prefer to not use removable jaw ones, for no great reason other than I'd be forever changing dies. Hence, I have a few brands. For insulated lugs/spades etc. different tool again.
I doubt you'll get a reliable crimp with those Dellortoman, you can't get the right pressure. The ratchet type are best, and come with interchangeable dies for different crimp types. To save money, you just buy the dies you will use. Ratchet is important. You should be able to find a similar tool like this at Jaycar in Tassie or online....
This is just an example.
Sure about that ? Ratchet crispers esp those elcheapo ones with removable jaws need to be regularity checked and dialed in. When was making harness for LPG conversions we quickly learnt the down side of cheaper ratchet crimpers…So I am with Cam on this one .. Oh and I can tell ya OEM dont use those insulated type crimps for a reason.……not sure its an upgrade using them to be honest think its more a backward step.. but like I often say what would I know right I much prefer to do the job using proper connectors
