I’ve been looking at these generic 20 ton press’s ( that one looks really nice actually) but apart from straightening forks, I haven’t needed one for years…but it would be nice in the corner.
Same here. One of those useful from time to time things.I’ve been looking at these generic 20 ton press’s ( that one looks really nice actually) but apart from straightening forks, I haven’t needed one for years…but it would be nice in the corner.
That’s the same model as mine but mine has red bits instead of blue. Doesn’t make it any faster though - my only complaint really but the power assisted version is a lot more expensive.
You'd be better off with a fire extinguisher Paul.Same here. One of those useful from time to time things.
With several bikes going and restorations to come, it'll come in handy.
Rebuild a Zane crank. Why?It’s what every Zane owner needs - to rebuild their crank...
Champion filter from the Formula with metal backing will also fit but expensive - bottom is the Punto one which is not long enough - to the left is the box for the Dacia Borg and beck one which was cheap and will just fit once the foam is removed from the top £7.50There are no windows in the garageargh, Adam socks and crocs
Could have been a wise precautionChanged the air filter on my Corsa - the one on there was a Punto one and not long enough so had an extra bit added
- there are three in the pic - at the top the original RGS , middle View attachment 91402View attachment 91403Champion filter from the Formula with metal backing will also fit but expensive - bottom is the Punto one which is not long enough - to the left is the box for the Dacia Borg and beck one which was cheap and will just fit once the foam is removed from the top £7.50
Good tool that Paul - used it to pull the speedo drive off the wheel bearing boss on the Corsa
Bloody paid for itself already!
That's an idea if needed.Good tool that Paul - used it to pull the speedo drive off the wheel bearing boss on the Corsa
My point was that those WERE the original ones.unless there is proof the rims are having the same or better strength than the original ones
