So... had some really weak yellow-ish sparks, swapped the spark plugs with an old (known good) set from my BMW (out of the head, plug metal grounded on the engine) and the same weak looking spark. With some fiddling got the bike to somewhat run, sounded like the choke was stuck (wayy rich), smelled of fuel and would not idle.
Just in case had a look at the choke, cables, etc, removed float bowls (spelling?) and cleaned it all up, no difference. There was a dead insect in there, how on earth did that get there with all the filters...??? As I put the Zumo adapter between the upper frame rails & routed all the wiring there, maybe I had fouled something, but it all looked good.
So undid my change before which it worked, removed the adapter from the Zumo from the coil, and away it fired as if nothing happened. Apparently even having just the adapter (empty bracket, no Zumo was in there) on the switched wire of the coil causes enough loss for a good spark?
Did a little test drive, back to as good as it was. Interestingly on my BMW I have the same setup but there it works without problems. Not sure if the Laverda parts are just old (coils, wiring) or the BMW works different. Or it still has degraded sparks but they are less noticable. IIRC the BMW has the same setup coilwise.
It did catch my eye there are NGK 10's in there, seems a bit cold for a GT and more for a race bike? Bike runs and works great otherwise, plugs weren't dirty or fouled.
Maybe a remnant from the sidecar days, full throttle in 3rd or 4th gear against headwind storms, or during engine work (engine has been opened at lease twice) the compression was raised, I'll have a chat with my dad about that.
Anyway, today was a day off, even though trains are running tomorrow I might get on the Laverda anyway. I did learn a lot about the bike, which is always a good thing.
Yes, you can all laugh at my idiocy now
