piranha-bro2
- Melbourne
Mine went on by hand - I'll have to replace it. not happy.
Gday Rob maybe that chain contact with the edge of the tyre isn’t helping that spline wear??The countershaft sprocket was quite loose on the spline. The spline is showing quite abit of wear. Is there a solution to tightening the fit somehow without having to replace it. It was a good 2nd hand one I replaced the worn original about 15000 kays ago when I last had the gbox apart. The original had done 170000 kays where as this one lasted 15000.
What causes it to wear?
I remember along time ago I fitted a new sprocket that seemed too loose to me. Can understand a sloppy fit would cause wear but the last sprocket was an interference fit.
Fitted a brand new 19T 530 cut down to 520 sprocket to the Q and was not happy that it's a loose fit on the spline. Just doesn't seem right to me. I'll be keeping a close watch on it. Much rather fit a new sprocket than split the cases and fit a new 5th gear output.
Zactly what I did, CK - not silly!Why turn the whole face off? Wouldn’t leaving the extra meat around the centre be better?
While the middle plug can be bit of a pain to get to …. I think you’ve taken things to the extreme.the day started well and I thought it might be a good idea to check the plug gaps..
Is that a supercharged Range Rover Andy?the day started well and I thought it might be a good idea to check the plug gaps..
Am impressed you can see it’s a Range Rover at all: alas, no, they’re both 4.6 HSE P38sIs that a supercharged Range Rover Andy?![]()
Nah - my attempt at humour was a bit too obscure! Referring to a certain Mr Paul le Clair and his engine removal technique!Am impressed you can see it’s a Range Rover at all: alas, no, they’re both 4.6 HSE P38s
When I looked for a new flat the deal was done when I saw garageNice workshop André!
the garageWhen I looked for a new flat the deal was done when I saw garage![]()
