- Auckland, roughly
Good news, thanks for thatTexted Chris. He said been busy steering the big rigs and has had no time for normal activities but all ok.
Presume will be back at some stage..........
I’ve seen less complete projects on EBay!The 3CE is a much less tax on my time now but I have spent a lot of time in my garage doing it so decided to make it a more present place to be. Hung up some signs and a few pictures; made a bit of a sculpture out of some of the Laverda bits I’ve got hanging around…….
I know that fairing. It was mounted on a Laverda 500. The bike was build by Gijs van Dijk in the Netherland, Color choice from the ownerThe 3CE is a much less tax on my time now but I have spent a lot of time in my garage doing it so decided to make it a more pleasant place to be. Hung up some signs and a few pictures; made a bit of a sculpture out of some of the Laverda bits I’ve got hanging around…….
I converted the bike to a Barcelona in 2012 and the fairing has been in the loft of my garage ever since.I know that fairing. It was mounted on a Laverda 500. The bike was build by Gijs van Dijk in the Netherland, Color choice from the owner.
Fairing is bottom Ducati F1 and upper part Pantah. The screen is Pantah. I used to have the same fairing on my Harris500.
Great pics of a great time. Thanks for posting SockPopped down to The Pied Bull, in Farningham, for the Annual Boxing Day meet. A decent turnout, despite the faint drizzle.
Didn't feel as warm as the Met men promised, but a good excuse to get the Laverda out and field the many "Is it a Jota?" questions.
Bumped into a guy I hadn't seen for forty-five years who'd once ridden pillion on mine, all those years ago.View attachment 94192View attachment 94193View attachment 94194View attachment 94195View attachment 94196View attachment 94197
Really interesting, and confirming your information, on consulting the SFC1000/RGA/RGS additional parts manual, the SFC1000/RGA is a smooth rounded cover, and has the tachometer drive taken off the inlet cam using cam cover part number 25 306 098, with the drive output racing rearward at 45 degrees.Wrong cam cover for a RGA. The tach drive doesn't line up nor is there space under the stock tank for the vertical cable exit from the inlet cam.
RGA/1000SFC had the tach drive exit from the exhaust cam between cylinders 2 and 3 at an angle of approx 45°. Both bikes used almost identical frames and basically the same fuel tank where only the filler differed. Correct cam cover is somewhat rare as the RGS cover isn't tapped for the drive gizmos.
Jota 120 used the cover carried over from the 180s, different frame, tank and cams.
Don't think so, guess you've got your cover arse about... drive cable exit faces forward.Really interesting, and confirming your information, on consulting the SFC1000/RGA/RGS additional parts manual, the SFC1000/RGA is a smooth rounded cover, and has the tachometer drive taken off the inlet cam using cam cover part number 25 306 098, with the drive output racing rearward at 45 degrees.
My engine is #RGS 02416, but according to the varied and many receipts kept, and passed on by the previous owners, there was major cylinder head work done by 'The cylinder head shop' in May ' 2005, including gas flowing, lead free valve seats, guides with valves supplied by the Laverda Paradies, and other accoutremonts supplied by Motalia. Also a receipt for pair of 120 degree Jota cams, and a 120 Jota cambox cover from Miura Engineering in Taunton. I can't find a receipt for a cylinder head, but I'm wondering if there had been a catastrophic top end failure, and a 120 head had been sourced to replace the O.E head assembly.
Interesting. The parts manual diagram shows the cam cover oriented at 180 degrees to the head, then.Don't think so, guess you've got your cover arse about... drive cable exit faces forward.
Starting with the RGS, all engines carried the "RGS" prefix, making no difference between models. Jota120 and RGS heads are identical, just different cams. Jota120 still had A11(12) or C4 cams depending on market, RGS recieved the new F1.
Really cannot see a valid reason for fitting a 180/Jota 120 cam cover on a RGA as there is no space under the tank for the tach drive cable. The cover will require a Jota 120 inlet cam for the tach drive. Was a diffent tank fitted at some point?
