Because the primary chaincase has a whole lot of moving parts and the oil gets splashed around effectively. The hole is there to top up the level, from the crankcase.And my question to those that know, if the static oil level is so close to the bottom of the primary drive oil hole. ( See photo) dipstick vertical, how does the primary chain,clutch, needle bearings etc get lubricated adequately?
The outer clutch drum is the lowest rotating part seems to only be just submerged in the static oil level. When the engine is running the oil level will be less. So I'm wondering how is everything in there getting lubricated. I guessed this area would be swimming in oil but it seems like it's not.Depending on the model year, it varies. Early 3Cs had, I think, 3 tiny holes between the primary so oil didn't move quickly between them. RGS had a pump-fed line directing oil on the primary chain itself and a much bigger hole between the cavity
Me too, first time in 46 years when I drained it out before removing the cover. Not much oil in there though.Because the primary chaincase has a whole lot of moving parts and the oil gets splashed around effectively. The hole is there to top up the level, from the crankcase.
I never used to bother, but I've now taken up the habit, on occasional oil changes, of removing the primary chain adjuster and draining the clutchcase before replenishing the oil.
That sounds about right. I did need slightly more oil to top it up after I ran it up today after replacing the parts. Primary side sounding much quieter now.I seen to remember about 300cc in the primary, that my 3c. It explains if I don't drain the primary why it only takes 2.7 litres or a touch more to get the dip stick reading right after a change. Some stay in the oil cooler as well, I guess.
This is my 3C, n° 2098. The top hole is the original. I drilled the bottom one to improve clutch oiling.Depending on the model year, it varies. Early 3Cs had, I think, 3 tiny holes between the primary so oil didn't move quickly between them. RGS had a pump-fed line directing oil on the primary chain itself and a much bigger hole between the cavity
There's plenty of oil in the 750 primary.Maybe when you lean on left-handers the primaries get some oil?!!! What that means for trips over the Nullarboring is anyone;s guess.
SFs have an oil feed hole in the oil pump body directed at the primary drive. The SFQ even has two!
Unfortunately, for nothing. It has been deemed that the alloy of the cases cannot be trusted after the fire.
Why would there be an oil seal on the main bearing, Vince? It's encased within the crankcase system - no way oil can escape into the atmosphere.I have a vague memory of there being no oil seal in the main bearing. Like the abundance of pre-72 V8s in Oz, I am probably wrong. Try a search here; the oil system has been discussed, and there is subtle stuff happening.
No need to pull out any hair over hypothetical problems. These motors do huge mileages without undue wear if they are maintained properly so it obviously all gets lubricated. I do not have any extra holes in my 750 clutch baskets and have done huge mileages and many seasons of racing with zero problems and many triples have similar experience. A good way to get through a night in the club cafe though, theorising about how it could work.
MetallurgyHow come, the only reason I can think of is micro cracks?
Fuck, fuckity, fuck fuck……. whatever happened to Padders?Metallurgy
3 or 4 studs pulled when I torqued the head, and they had been Timeserted. The head is warped beyond hope anyway.
There was a micro crack about 10 cm long and 1 mm wide above the gearbox sprocket which was laser welded.
Not worth the risk.
I was warned not to buy salvage of FZR1000 from a burnt motorcycle shop, I wanted the engine but the wheels had melted like candles & were flat at the bottom! Fire investigator told me temperatures of the fire were insane. Best avoided.Metallurgy
Not worth the risk.
