That bit of your boot flexes while you walk, so I reckon a leather pad might work better than a metal plate and would probably have a better chance of staying stuck. My boots have leather doubler pads stitched on for exactly that purpose. If the Sikaflex doesn't hold (BTW, there might be better stuff for gluing leather) you could take it to a boot repair shop and get them to sew a patch on. I think they have sewing machines that can reach inside a boot.I might shape up some thin alloy and try sikaering that on to armor it.
That would go well with your nice rack.I wonder if anyone takes a pic of my nob on the weekend.
I've already thought that when i saw them - just haven't got around to finding one - are they a regularly available spare part? My homegrown rearsets use a Jota (RH) gear lever assembly and a 3C short gear lever as a brake lever that operates the rear M/cyl. You can imagine people trying to ride it who are used to left foot gearchange - won't go into first and hard as a rock and won't go into second!!Why not replace it with the standard RGS-type plastic knob? Simple screw-on job and looks as if it belonged there...
I'll check for you Quentin. I think there are some in stock.I've already thought that when i saw them - just haven't got around to finding one - are they a regularly available spare part? My homegrown rearsets use a Jota (RH) gear lever assembly and a 3C short gear lever as a brake lever that operates the rear M/cyl. You can imagine people trying to ride it who are used to left foot gearchange - won't go into first and hard as a rock and won't go into second!!
Thanks Piet. I've had Jota levers (foot and motor) since the late 70s (came off an insurance repair I did in the shop). I use a reverse pattern and shifting effort is excellent.I'll check for you Quentin. I think there are some in stock.
If you haven't buttoned up the engine, why not swap the entire gear change mechanism for triple bits? This will ease up the shift effort to normal levels. Or use the internal 750 drum and external tripe parts to reverse the shift pattern, if so desired? All sorts of possibilities...
mate 10 of us Qldr,s coming to walchaYes Paul, maybe an Eastern Creek race meet I think. I love riding in cold weather, but not so much cold and wet. I was reading the Oxley MIGHT have one lane in bits open in July. Not so much looking forward to coming back The New England, done it to death in the car the last 3 years.
Has to do with the geometry of the change mechanism. 750 uses a long pawl gate, triple short. This coincides with the gear lever length. But, as the pawls engage on opposite sides of the small selector drum, pattern is reversed, large slector drum is mirrored. Need to do some thinking before you commit yourself.Thanks Piet. I've had Jota levers (foot and motor) since the late 70s (came off an insurance repair I did in the shop). I use a reverse pattern and shifting effort is excellent.
Had no idea triple parts would make a difference - I did know the internals attached to the splined shaft under the outer cover were different but never gave any thought to why. Were they designed to improve shifting? And is that why the 3C could use the short gear lever? (which I fitted to my SF1 but was always horrible on the foot, and was turned into my brake lever when I made the switch to rearsets - and a whole new world of ergonomic benefit!)
So the large selector plate that controls the forks in the gearbox has a mirror pattern and thus starts in 1st where SFs have 5th? Does that selector plate fit straight into the SF internal drum? If I can source all the bits for less than the silly prices I see on FleeBay I might consider. But then by 'tuning' the ratio of my rearset linkages I'm really doing the same thing aren't I? I have to say with my setup shifting is totally transformed c/w the std SF.Has to do with the geometry of the change mechanism. 750 uses a long pawl gate, triple short. This coincides with the gear lever length. But, as the pawls engage on opposite sides of the small selector drum, pattern is reversed, large slector drum is mirrored. Need to do some thinking before you commit yourself.
