Despite my lack of facilities the SF2 is rising (sort of) from the ashes. I will try provide pictures of my butchery of the original engine later, it certainly hasn't been a pleasure
I have acquired another bottom end from and SF0 which was supplied by a kind ILOC member and at the moment I'm trying to separate everything from the original crankcases.
The whole lot was a disgusting rusty slimy mess with solidified lumps of black gunge sitting in the bottom of the cases. Every bearing was rusted solid and in the end I gave up trying to batter the pistons from the bores and sawed through a con rod to get the cases apart. Ged Shorten told me you can't buy them anymore but I'd had enough.
All the gears are eaten into, I used heavy duty degreaser and the citric acid that Cam advised but even that didn't shift the scabrous rust from the cogs. The clutch is absolutely corroded together, you would have to saw the drum up to free it.
So after this, what is left? I think maybe the starter motor, carbs, perhaps the dynamo, some casings but luckily, the cam followers, cams, valves etc and the cylinder head itself. One valve seat has a bit eaten away but it's not terminal I don't think, I'll ask Ged.
Today it took me all afternoon to get the rusted up locating pin out of the gear selector shaft and to pull the shaft out of the selector drum. The oil pump screws aren't going to give up without a battle either. Soon the cases will be cleaned and ready for assembly, I don't have any pistons yet but at least I have a spare set of barrels. Some fancy pistons going cheap in Sweden I believe (joke).
I don't know whether the bike will finish me first or I will finish the bike.
By the way those crankcase castings look rough as a dogs bottom internally but I suppose that's normal?
